- Joined
- Aug 28, 2006
- Messages
- 2,330
Anyone see a problem running a PF52 instead of the specified PF47? More specifically, O'Reilly's has on sale the Mobil 1 Extended Performance oil and filter for $35. I was thinking of using the M1-201 (PF52) filter instead of the M1-101 (PF47).
Application is an 2005 Chevy Astro van w/ the 4.3L V-6. The filter is vertical and the added length of the PF52 will not cause the filter to extend below the oil pan, come near the exhaust, or contact another part.
The older Asto vans specified the use of the PF52 but for whatever reason GM switched to the use of the PF47 beginning in the early 2000 MY vehicles.
I am currently running Pennzoil Platinum 5w30 and change the oil every 7000 or so miles and have always used the PF47. I usually go all winter w/o an oil change on this vehicle as the van most likely will not see 7000 miles between October and April.
Any comments will be appreciated.
