Following up...
My ac clutch was not engaging.
On May 12 I removed a shim from the ac clutch. I sanded down the ac clutch to clean off the rust. The AC clutch now engages. I also added some refrigerant. I used the gauge attached to the can to see how much to add. I used ac gauges May 20th and when it was 66 degrees outside, my low was around 33psi and high was around 157psi.
My ac hadn't been feeling cool enough, so I added more refrigerant making sure I didn't overfill (I kept an eye on the gauge attached to the can of refrigerant.)
Everything has seemed fine, but the ac seemed to work best when driving long distances on the highway. The ac temperature would fluctuate a little at idle. However, today was in the high 90s, and my ac clutch would only intermittently engage. It was awful. Seemed like the hotter it got, the worse it engaged, and I had no cold AC. Tonight, I checked the refrigerant levels with a set of gauges. I was able to let my car cool down for a few hours, then right when I started the car, I checked the levels before the AC clutch had a chance to stop engaging. At 86 degrees, my low side read around 53psi. The high side read around 400-450psi. My low side seems good, but my high side seems really high.
I switched relays, and nothing changed. Both fans are running, but they do stop sometimes, then turn back on. I have read it could be the condenser, the thermal switch/protector, or ac clutch. I'm sure there are other possibilities also.
Any help is appreciated!
