I’m trying to track down why a 1998 Ford Ranger I work on is blowing hot air despite being in AC mode. Checked the charge and it was a little low, added some virgin R-134a and UV dye. The pressures are fine now, 32/245 on the low/high sides. The electrical side of the system checks out - checked the relay with a Chinesium Power Probe clone - power and ground present at the relay, I can hear the relay click and the contacts are good. I also checked the AC clutch plug, also has power and I can see the HVAC control switching the ground on and off.
This leads me down two paths - vacuum leak at the dash connector for the HVAC damper doors or condemning the controls but I’ve been reading a bad blend door actuator or broken blend door might be at play. Am I going down the right path?
