Absolute best sludge/varnish cleaning CONVENTIONAL oil..
How much percentage of synthetic blend oils like Castrol GTX HM and Pennzoil Conventional are actually synthetic? Is there a way to know?
The question is does it actually gain you anything?
Both of these are API SN+ GF-5 5w30:
I'm just going to give percent of base to nearest 10% as opposed to total including additive and carrier to avoid any confusion.
These are example oils I happen to have a general idea of and DO NOT represent GTX or Pennzoil.
GII 60% / GIII 40% - 15% Noack
GII+ 70% / GIV 30% - 10% Noack
My point is the quality of the GII and GIII/IV/V you use will effect how much of the GIII and above you have to use to meet various specifications. The highest amount of "Synthetic" may not even be the best base much less fully formulated oil. Of course you have other issues like the viscosity of the bases you are trying to use but I'm trying to keep it simple.
Poured a bit of MMO in during the last thousand on several occasions. Tried High Mileage Rislone this time. Actually seems to have shut down some light oil burning, something MMO (probably because it burned off) didn't.
Sounds good. I'd stick with the Rislone and give it another shot next time around, you may have cleaned up the ring packs too. Two back to back doses might get things nice and clean. You can't go wrong for the cost of it either.
Well me personally, I am just looking for as “pure“ of a group II 5w30 I can find if that even exists.
I believe to make a straight Group II it would have to be a high GII ie GII+. Pennzoil was through SN. Chevron might be. Quaker State might be. Mobil Super might be all EHC (Group II and II+). I don't know if anyone can tell you for sure. I mean they can call GIII conventional or synthetic.
May I ask why you are trying to avoid Group III?
I believe Schaeffer's 7000 is GIII free but you would have to live with the Group IV PAO they replace it with.
I intend to throw some High Mileage Rislone in for the next change too, as soon as the Valvoline Daily Protection burns down a bit. Always found Valvoline conventional to burn off a bit in any car I've used it in. Interesting the OP wants to use conventional, I'd be using full synthetic except I'm a geezer living in a condo where they'd send me a warning letter if I was seen under the car, haven't changed my own oil in 25 years. If I did, it would be a no-name syn like WPP all the way. However, in addition to not being able to drop my own, I have a bunch of $10 oil, filter and rotate coupons to burn through.
I, too, am curious about the OP's aversion to Group III. Don't think you're going to get many SN+/SP oils that meet standards with just Group II other than the above referenced XOM, and I'm not even sure that's a go with the new SP standards. You're not one of those people who complains about Valvoline Daily Protection being a blend on Amazon are you?
A 10w30 should be an easier find for a pure conventional than a 5w20-30.
This is as good a place to put this comment as any. It seems when I got on here in 2002 there were a lot of comments that the add pack was more important than the base oil and that a strong conventional like Pennzoil conventional was the way to go. Don't here that much any more.
Dollar for Dollar I would take Schaeffer's 5w30 Blend (Group II+/PAO) over many "standard" Synthetics so I don't think that's changed. The problem is I can buy Mobil 1 ESP cheaper so it's a money issue not a base issue.
For my next oil change I’d like to go with as conventional of a oil as I possibly can and see for myself whether or not it makes a difference in a couple of leaks I have.
If you really want to break down sludge,varnish and carbon I would look for a healthy dose of ester in my oil. Valvoline was selling a highly concentrated mostly ester oil for cummins carbon issues, $$$. Or maybe Red Line white bottle for a couple thousand miles followed by previous suggestions.
I don't think you'll find any "Conventional" 5w30 anymore. Historically conventional 5w20 and 5w30 are now labeled on the packaging and/ or described in the PDS as "Synthetic Blend".
The closest you'll get may be with more viscous grades, i.e., 10w30/40 and up.
If I had to take a stab at it I would go with Quaker State 10w30 SN/SN+. However I highly doubt it will accomplish anything Valvoline MaxLife Blend couldn't.
I don't have any confidence that any 5w30 is going to be completely GIII free.
So I went with my gut and returned the GTX for Pennzoil 10W30 HM. Same price, but I know the Pennzoil has a proven track record of cleaning. I'm really unsure just how much sludge/build up is in there, and I think gently removing it over time will be best. Dropping the oil pan is time consuming (axle and rack and pinion have to be lowered).
SuperTech filters are cheap, so I'm going to buy several to keep on hand and change the filter every 1,000 miles or so, and do 3,000 mile OCI's to try and get out what I can without knocking a bunch of crap loose at once.
Donald said above, "...if gooey how about a gallon of a solvent like mineral spirits in a pump sprayer spraying the area over and over let it drip into the oil pan which has the drain plug out and a catch pan below. Engine off."
As a subsequent step to this I'd catch the drained solvent, run it through cheese cloth if necessary then reinstall the drain plug and do it again. This time let the solvent sit in the pan so it soaks the pick-up screen.
New engines should have fiberoptic viewing holes from the factory so guess work could be eliminated.
