Aramid (Kevlar) reinforcement helps as well.the year they started using EPDM
If the original hoses say EPDM on them, they are not wear items to be replaced at regular intervals.
Very interesting!Not sure where this was, but over here that's definitely a thing. You're lucky if you get 4-5 years out of an aluminum/plastic radiator in a vehicle that's been driven all throughout summer, before it gets all brittle and starts cracking like an eggshell. A lot of people here replace them as "preventive maintenance", especially those with all-aluminum engines.
And belts aren’t far behind either. I went to a Gates seminar/class a few years back and you know it’s not good for Gates when they have to sell their belts like this...you can’t really tell when are belts are worn visually anymore, use this little gauge instead because they rarely crack or show visual wear. Another reason why you’d want to change a belt (that appears visually good) is because a worn belt will cause your alternator to work harder (minuscule slippage) and throw random charging and check engine lights. If you get random electrical issues and check engine lights, change your belt.
Yea, technically the grooves in a drive belt will wear out but until you're actually getting slippage (which IMO is usually due to poor tension), there's a whole whackload of safety factor in there. The EPDM in a belt could almost all dry rot away and you'd still have the carcass in there holding it together.
I would say around the early 2000, is when I noticed the quality of the rubber hoses and other components started lasting the life of the vehicle .Changed all the hoses on my '08 Hyundai Accent at 150k. Almost all were still in good shape. What goes on Hyundais is the OE clamps. They either lose their tension or rust asway. Had to start replacing them at 100k.
