for my Lexus cleaning purpose , 5k oil change , since the main purpose of valvoline RP is to cleaning , which oil filter that best to catch everything.
No, the main purpose of Valvoline Restore & Protect is to lubricate your engine. It's motor oil. It's not a flush. It's not a solvent. It's not going to do a lot more than any other modern quality motor oil will. You're not going to have a bunch of gravel circulating around in your engine by using it necessitating using a better filter.for my Lexus cleaning purpose , 5k oil change , since the main purpose of valvoline RP is to cleaning , which oil filter that best to catch everything.
That’s the takeaway I got from the video as well. A slow cleaning over roughly 4 OCI’s. In the Q&A section Valvoline states ( paraphrasing here ) no need to deviate from your normal OCI procedure. Im planning on 5,000 mile intervals and I’m using the AC/Delco PF30 on my 4.3 DI with their R&P oil.VL addresses overloading of the filter at manufacturers recommended intervals in the LSJR YouTube video. Apparently it was a consideration so probably nothing to worry about or change filter wise.
^^^ This ^^^fram endurance if sold in correct size
@I<3oilConsider the Purolator BOSS. I've seen a spec sheet that indicates 8 grams of dust holding capacity, which I believe is on the high end. I don't know if Fram discloses this spec.
#1 is good, #2-5 are basically low efficiency rock catchers. If one has to use Mann, at least the Boss is durable & has high holding capacity.1.Fram endurance,2.Purolater boss, 3 wix xp, 4 Napa platinum, 5 Mobil 1 oil filter .
