4wd
$50 site donor 2026
The Ford 3.3L DOHC V6 has PFDI too …Ya I know Lexis has been doing it for awhile and VW did in Europe.
Does nothing, huh? Completely ignoring the fact that it's more of a solvent than oil?No. LSPI is caused by liquid oil inside the combustion chamber. MMO is not going to do anything and frankly I wish MMO was a banned topic. People attribute all sorts of things to MMO when it does nothing.
Ban it forever!!!!!Does nothing, huh? Completely ignoring the fact that it's more of a solvent than oil?
https://bobistheoilguy.com/forums/threads/laboratory-analysis-of-mmo.221152/
In direct injection engines petrol (solvent) does not get to travel through the intake manifold and wash the intake valves. That is where this drip injection solution comes in, as it gets to apply the solvent power to keep the intake valves clean.adding solvent to engine oil= engine flush
adding solvent to petrol - makes no sense, it is already a solvent.
where u would put it? if close to throttle body, then this mist may condense too early in the intake (plastic) pipes... and it may not arrive to last 1-2inches around valves-where it gets hot and where the spray is needed most.vacuum drip-injection system
Looks like $30 seafoam.I used this product recently and it seems to have improved things in my 2014 Focus With GDI.
I wasn't feeling any issues prior to using this product but I felt that I might as well do some IV cleaning for the first time as my Focus approached 60K. The car did idle smoother and seemed to run better afterwards. When I purchased this STP product last year it was $29.99 at AZ 'on sale' from $39.99....now it's $29.99 everyday price.
https://www.amazon.com/STP-Pro-Inta...ive&sprefix=STP+in,automotive,681&sr=1-1&th=1
It's true that you could buy CRC or Seafoam for about 1/2 the cost of this product but the way it's 'dispensed' makes it easy to use. OTOH you could pay $150 or more for a 'professional' intake valve cleaning and it would probably get similar results.Looks like $30 seafoam.
Thanks for posting that. Really neat set ups. I worked for a mechanical engineer who devised a system very similar for use on some older boiler / power house equipment. This was 26 years ago so I kind of wonder if he saw this or invented his own. It worked great at the time. He was pretty sharp.Basically just a drip oiler, operated by engine vacuum. Seems to make sense in many applications. Obviously don't see many Direct Injection users (yet), so brought this product from the dead for discussion.
I thought it was designed for oil at first. I see now that they were using the dreaded Marvel Mystery Oil. I think the mystery is (its a solvent) called an oil. Been using MMO since about 1975 or so on advice of mechanics and a couple engine builders.Basically just a drip oiler, operated by engine vacuum. Seems to make sense in many applications. Obviously don't see many Direct Injection users (yet), so brought this product from the dead for discussion.
My Chevy Cruze Diesel that had the head pulled at 30k miles to clean all the gunk causing driveability issues may disagree with your statement.Toyota and VW/Audi are two off hand which implemented secondary port injection on their DI engines. Today the reality is that carbon build up on DI engines is NOT causing drivability issues. Automakers have developed tricks to address it (ex, better PCV systems, injection of some fuel while intake valve open.
Yes some buildup may be present but it's not the same as build up which impacts drivability or performance (power, FE).
Chevron with Techron.I am not affiliated with this company in any way, shape, or form. But seems like it could help with many carbon and LSPI issues of the Direct Injection engines. I may be overlooking something though, so feel free to post your opinions and facts on whether this is a good/bad idea and why.
From their website:
Expect These Benefits
-Increase in fuel economy by reducing friction
-Reduced valve-to-seat wear
-Eliminate sticking valves; quieter valve train
-Removal of carbon deposits which cause pre-ignition
-Protection of valve stems, guides, seats, rings, and cylinder bores
-Increased compression, power, efficiency and engine life!View attachment 74842View attachment 74843View attachment 74844
Mind explaining how Chevron with Techron gonna clean the intake valves in a direct injection engine with no secondary port injection?Chevron with Techron.
That has mostly nothing to do with DI but everything to do with EGR which is common for diesels.My Chevy Cruze Diesel that had the head pulled at 30k miles to clean all the gunk causing driveability issues may disagree with your statement.
I think it's the best cleaning otc gasoline you can run. I ain't mechanically changing my engine for a possible issue 100,000 down the road. JmoMind explaining how Chevron with Techron gonna clean the intake valves in a direct injection engine with no secondary port injection?
Found that article and had to read it again,There are so many "claims" out there today it is hard to keep up with them all. Just last week I found myself reading what appeared to be an official Valvoline (nothing against Valvoline oil - used it for years) page that was describing all the wonderful new innovative changes that have gone into their latest motor oil. Even "claims" to help prevent and keep intake valves clean in Di engines. Then in the tiny, small print at the bottom I am sure most folks do not read..... something to the effect, "these are the opinions of the writer and in no way is verified!" YIKES, why even write an article and post it like that?
