Originally Posted By: billt460
.454 Casull. 65,000 PSI! That's more than a .460 Weatherby Magnum. It's not uncommon to have around 15% to 20% of factory ammo split the cases on the first firing.
If you want even more over the top, the 460 S&W Magnum adds some length to the 454 Casull case. The peak pressure is the same, but all else being equal case volume is king. A 460 Mag can manage well over 2000 fps with typical ~250 grain bullets.
I'm still kicking myself for not buying the Freedom Arms in 454 I found in a pawn shop a few years back for $900. It was in beautiful condition and still in its factory wood box. I don't think they knew what they had, as Freedom basically makes bespoke guns and starts at around $3K. It was-without a doubt-the nicest finished revolver I've ever handled(and I've handled my fair share of Pythons and the like). The cylinder gap was so tight that I could barely see through it(it had to have been .002), there was no perceptible end shake, and the action was bank-vault tight. The action was slicker than snot.
