Hello,
Quite confused though, I noticed Brake light is on at all times in instrument panel cluster. I checked brake reservoir is completely empty.And then I noticed there is a leak between Master Cylinder & Brake Booster. I tightened the 2 bolts holding the Master Cylinder to the Booster and drove it a mile and there is still leaking. The brakes seems normal though. May I ask which one is the culprit between the 2? BTW the vehicle is a 1984 Isuzu P'up truck
