A few pics of my dirty HVAC ducts...
Michigan
A few pics of my cold air returns before they get cleaned. Not cleaned in at least the 26 years I have had the house.
Time for a cleaning. Did you get it done yet? 26 years is a long time. Do you have pets?
Was supposed to be today but tech was sick. Reschedule for Sat.
We have 3 dogs now. Have always had 1-3 dogs/cats over the years.
  • Like
Reactions: JC1
Things hide in there and its not all dust and stuff,,,creatures ...................how do I know,,I installed ductwork a long time ago.
I'm not sure I get the logic behind cleaning ducts, unless there is something more harmful than dust in there, or airflow is restricted significantly. The dust was in the air, and now it's not. Why is that bad? If dust settled in there and the underlying cause hasn't been corrected, it would stand to reason that the ducts will be dirty again in short order.
Fire/explosion hazard
the dust dislodges when you run AC/ heat making indoor air quality worse than the incoming air.
When the air quality coming out of the returns is worse that the air going in you have a problem.
If you use better filters you can avoid that buildup.
