A change in direction
OK I've been running SSD in my mid-tower for about a year now. Every spinning hard drive would have some annoying noises, which I was sick of being distracted by.
Also, running a core2 duo, I thought the faster access times would be a blessing.
There is a noticeable difference is access times, bootup times, however you want to measure it. And not hearing a whining disk is great. It's like whatever was slowing Win7 down is gone. Money well spend if one likes speed and quiet.
One thing, you might want to check and see if your bios does AHCI. Wiki: AHCI definitely does show an increase in performance for most SSD's but it's not going to be noticeably different from IDE unless you're benching and reading the actual speeds. Here's a good review and testing session with a lot of info on AHCI as well:http://benchmarkreviews.com/index.ph...=505&Itemid=38
Also, Win7 will align the partition installation automatically, and supports TRIM. Vista SP1 native install disk will align also, I am told. Not sure about TRIM.
Originally Posted By: barlowc
Look at the Dell Outlet. (http://www.dell.com/outlet) There are some good deals there.
Agreed. Every PC I own (5 in all) was purchased from the Dell outlet, usually at about 2/3 of the new cost. To run SQL, the databases that I design and test, as well as several virtual machines for testing, I can purchase a server grade workstation for the price of an average consumer PC.
OP-- I have used dell sound bar on my work computer for 5 years. I buy it for every Dell that I order for work (Dell is our preferred provider). It is perfectly OK for music/web/non hifi.
BTW 510PA comes with a power adapter, 510 plugs into a 12V power port on higher-end monitors.
Another idea for a monitor, $179: LCD TV: http://www.bestbuy.com/site/Dynex%26%23153%3B+-+24%26%2334%3B+Class+/+1080p+/+60Hz+/+LCD+HDTV/1894282.p?id=1218346039664&skuId=1894282&st=24%22%20dynex%20tv&cp=1&lp=2
I had to get a new monitor after my 10 year old 15" MAG quit. I bought the 22" version of the one I linked to for $100.00. Picture quality is great, sound is good, and I watch TV on it (PC was in the bedroom at one time).
