Days of $2/qt oil are over. Seems like $3/qt is the new "cheapest oil" category standard. One hero stands tall in that category - Super Tech Heavy Duty 15w40 at $11.74/gallon, which works out to $2.94/qt. Or $3.58/qt if you buy in 1qt bottles. Or $2.92/qt if you buy in 2-gallon jugs.
Realistically - this oil can successfully be used in a 1-cyl air cooled motorcycle, a 3-cyl Mitsubishi Mirage, or 16-cyl Bugatti, as well as everything in between. May not be the correct spec, but it will do the job, as long as it's within the temperature limits of 15W-40 (which in general is roughly -15C to +40C or 5F to 104F), and shouldn't cause any oil-related issues that have to do with level of protection that this oil offers. Some engines have factory defects, and no oil can stop those from blowing up or spinning a rod bearing. So we'll leave those out of this exercise (BMW V8/V10 for example).
The Mental Exercise: in a wide range of automotive engines and vehicles (ignoring motorcycle engines with shared sump) can we come up with scenarios/vehicles where Super Tech 15W-40 won't be able to protect the engine well enough? For the sake of the exercise let's say that said engine won't see ambient temperatures outside of 15W-40 range, and engine isn't a subject to overheating issues. Period of protection needed is 150k miles with 3k-5k OCIs. Go.
