This is oil related.
Super Tech Full-syn 75w90 (is almost too good to be true).. For $5.86/qt you get this.. according to walmart.com https://www.walmart.com/ip/Super-Tech-Full-syn-75w90-Gearoil-Qt/309470123
Super Tech Full Synthetic 75w90 Gear Oil Quart Super Tech 75W-90 Full Synthetic Gear Oil is formulated with synthetic base oils to provide superior gear protection over a wide range of operating and ambient temperatures. Made with premium extreme pressure additives, rust preventatives, and antifoam additives, this oil protects hypoid gears, manual transmissions, gearboxes, passenger car and light truck conventional differentials, transmission and steering gears.
Formulated with 100 percent synthetic base oils
Provides superior gear protection
Made with premium extreme pressure additives, rust preventatives and antifoam additives
Recommended where API GL-5 and MT-1, MACK GO-J, SAE J2360 and MIL-PRF-2105E (PG-2) are specified
The label has no mention of MACK GO-J, SAE J2360 and MIL-PRF-2105E
Obviously someone gave information to Walmart to publish those specs.. however that someone did not feel the need to print on the label.
The closest you can come to getting any kind of wording about SAEJ2360 and Full Synthetic is Valvoline at $14/qt.
Do you trust the 'Recommended where..' only to be found on walmart.com? Or do you pay $7 more a quart for the true cert oil?
