The car is a Geo Metro clone w/4 cyl and I need to change coolant this weekend. From the factory it came with had the traditional green. Should I....continue to use the old green or put in some GO5? I have a stash of both.
I think I would drain the block and flush the cooling system before switching to G-05. From there I guess it's your call if you want to use up your stash of green before using the G-05. Some might say that both traditional green and G-05 have silicants but traditional green seems to work fine in Japanese engines. Green just doesn't protect for as long.
G-05 is completely compatible with older cooling system that ran traditional green. This is why John Deere states it can be used in tractors all the way back to the 1960s.
