- Joined
- Sep 28, 2002
- Messages
- 39,798
This is the second run for PP 5w-20 in my wife's 4.0 Jeep Wrangler. Wear is down in most numbers by a decent clip. Fuel adds were used near the beginning of the OCI in an attempt to eliminate any fuel issues as early as possible. The countermeasures appeared somewhat effective as fuel dilution was nearly cut in half and, naturally, the flash point improved in concert with that reduction.
1st column current UOA 2nd column last UOA
Miles on engine: 129600/124590
Miles on oil: 5010/4700
Air filter: New Purolator P+ (not the PureOne version)
Oil filter: EaO57 (FL-910/PH3614 size)
OIl: PZ Plat 5w-20
Sump size: 6 quarts
Make up oil: ZERO
Fuel adds: RLI and Amsoil PI
FE: 21/31
Cu: 11/21
Tn: 0/0
Pb: 7/12
Cr: 1/1
Nk: 1/2
Brn: 33/56
Al: 7/9
Si: 12/23
Na: 6/9
Pot: 0/0
Cal: 2300/2618
Mag: 28/82
Zn: 852/1119
Phos: 740/927
Bar: 1/0
Mol: 49/72
Ant: 0/0
Visc 40C 45.6/462
Visc 100C 8.3/8.1
TAN 2.24/1.30
Flash point: 365/305
OX: 23/19
Nit: 12/11
KF: 458/480
TBN: 6.1/8.6
Fuel: .799/1.42
Soot: 0/0
Glycol: 0.24/0
Visc index: 155/150
I'm please with the improvement. It proves to me that viscosity isn't a panacea for all ills in your engine. It can maybe mask a few things. AFAIK, this engine was never spec'd for a 20 weight in it's existence ..and surely nothing in this weight and an SM. Lead is my one thorn that I'm annoyed with. The rest just needs some continued massaging to straighten out.
Admittedly, this was only a 5k run. Not bad in itself given the out of spec usage, but it won't work in my desired OCI time frame. 6 months 9k is the minimum I can do. I was going to use Amsoil HDD 5w-30 next ..but this UOA has me tempted to use Bruceblend Superduty 0w-20-lite. My only reservation is that it's so highly additized that it will provide trace additive elements in future UOA ..probably for some time to come. I don't like to cloud any properties/effects of any future oils. I will ponder this for a few days. The sump hasn't been changed yet and I need to order a couple more EaO filters.
I really can't say enough about Terry's service. I highly recommend that you experience his service at least once. He's now added an audio component to his interpretation and has a new look to his text report with pointer actuated notes that expand when you touch them.
Questions and comments are always welcome...
OIl: PZ Plat 5w-20
Sump size: 6 quarts
Make up oil: ZERO
FE: 21/31
Cu: 11/21
Tn: 0/0
Pb: 7/12
Cr: 1/1
Nk: 1/2
Brn: 33/56
Al: 7/9
Si: 12/23
Na: 6/9
Pot: 0/0
Cal: 2300/2618
Mag: 28/82
Zn: 852/1119
Phos: 740/927
Bar: 1/0
Mol: 49/72
Ant: 0/0
Visc 40C 45.6/462
Visc 100C 8.3/8.1
TAN 2.24/1.30
OX: 23/19
Nit: 12/11
KF: 458/480
TBN: 6.1/8.6
Fuel: .799/1.42
Soot: 0/0
Glycol: 0.24/0
Visc index: 155/150
