When I turn the headlight switch on to parking lights or headlights, the instrument cluster illumination doesn't work. Neither do the illumination in the shifter, hazard switch, power window switch, etc. The light in the rheostat does work and goes from dim to bright as the wheel is turned. The radio display goes from bright to nothing when the lights are turned on. Any thoughts to what's causing this?
