Below are the results of three successive oil analyses, with three differents brands of oil. I now know that comparing the results isn't completely fair because the additive packages of different oils may compete or counteract each other. Still my naive evaluation tells me that Mobil 1 isn't all that's it's touted to be, By the way that was the older Tri-Synth (the "good" stuff). Castrol Syntec looks like it did pretty darned well. The Syntec was run late spring to early fall, so it was exposed to warmer temps (OK, it doesn't get all that hot in upstate NY) and boat towing. The iron number for Schaeffer's bothered me a little bit, but that lead number is very important as the main bearings in this engine utilize lead.
The vehicle is a 1998 Chevy Silverado 4x4 with a 350 engine (the "old" style 350). It sees mostly highway miles, and I don't drive it hard.
One last observation, and I made this observation in my post about my Passat. Although the silicon numbers are almost identical, the first and highest was when I still had the OEM paper element air filter installed. The other two were with a K&N filter installed. I don't feel so nervous about K&N anymore.
One last thing, all oils were 5w-30, and I think I used a Purolator Pure One for all of those changes.
code:
brand of oil Mobil 1 Castrol Syntec Schaeffer's
miles on sample 5000 6700 5400
vis. 100C 10.7 11.1 11.3
% oxd. 24.4 25.6 27.8
% nox 37.1 31.4 25.7
TBN 9.9 8.4 4.9
iron 36 23 35
chromium 2 1 1
lead 52 50 34
copper 7 5 5
tin 6 4 4
aluminum 1 8 8
nickel 1 1 1
silver 0 0 0
mangenese 1 1 1
silicon 27 24 23
boron 59 35 35
sodium 21 11 128
magnesium 2194 602 304
calcium 1236 2097 1699
barium 0 0 0
phosphorous 1006 1124 1012
zinc 1247 1215 1152
molybdenum 9 26 76
titanium 0 0 0
vanadium 0 0 0
cadmium 0 0 0
