hi all. 98 corolla VE model. yesterday, i finished installing a new aftermarket evan fischer exhaust system. what a pita it was! Mainly too trying too get the middle pipe, 2 segemnts connected. and...installing the 3rd piece, catalytic converter and front pipe, one big unit, and a bosal doughnut gasket. New muffler too. I have new flangebolts, springs, the guide, i bought at autozone. doorman brand. they fit. oh got new 02 sensors too...
INstalling the new flange bolts, front exhaust pipe...i tightened the bolts till the sorings were smashed tight looking, not incoiled looking. Few hours earlier, i had left them 75% turned, so the springs appeared looser started car, and some smoke im assuming exhaust came from connection area their. why i tightened them so tight.
i do know, the top of the bolts ride the bottom flange too allow felxibility. well after tightening so tight, small leak at mid pipe. use aluminum tape, and 2 inch connector. seems too have stoped it, as their was air coming out a small seem of the connection. not after the tape and connector. muffler and gasket didnt leak.
did i over tighten the front pipe flange gasket bolts? tookfor a drive, and their still a small leak somewhere. it rides pretty ok..but when going after stop, theirs a visible exhaust noise then it stops.
or...what would be the correc torque specs fro the front pipe exhaust doughnut flangle bolts?
imthinking of getting some liquid metal stuff i triedmonths ago on a small hole in old 18 year old resonator under the corolla it worked flawlessly.
