Originally Posted By: SL2
Guys, well my Sl2 the transmission blew, Im looking for another car, found a 96/7 Jeep 4Wd automatic. Went from 35Mpg to under 20.
Well anyways, It has around 140K miles, I really want to use some kind of synthetic, but being it has so many miles, do not think i will, only because i guess there are know to have to rear main seal leaks...
Anyways, this is the first time i have a suv, and have no idea what wt oil to put in it, I dont think its not 5-20/30 as they seem a little thin, How would 10-30/5-40/10-40 do?? again, i may use like Super Tech synthetic, but it takes around 6Qts total.. What is the correct filter size? I dont think i need to worry about an over sized one, and again what would be a good OCI? 3-4K miles on conventional 5K on synthetic? Ok so all in all
-Best oil, Conventional or synthetic
-Best Oil Wt summer/winter
-Oil Filter size/number
-OCI's
Thanks!!
Don't fear synthetics. Jeep 4.0s seem to *love* Rotella T synthetic 5w40. I posted a ~5000 mile oil analysis on mine recently, and it was very, very good:
http://bobistheoilguy.com/forums/ubbthre...rue#Post1437776
We just changed that fill out yesterday at about 5500 miles. It could easily have made 6000+, but I'm not going to have a chance to do the work again for a while. My Jeep has just under 130k miles- just getting broken in for a Jeep 4.0! Don't call a 4.0 "high mileage" unless its got well over 200k on it. If you prefer an Xw30 oil, that's fine too. Factory recommendation is 5w30 or 10w30, but the new 0w30s would be even better. I plan to try a fill of Mobil 1 Advanced Fuel Economy 0w30 in the fall to compare to this current fill Rotella, which is the first batch I've run that is the new SM rated formulation.
If you worry about the idea that PAO synthetics will cause old seals to leak (I don't believe it nor have I experienced it personally) then you still shouldn't worry because Rotella T Synthetic is a petroleum-derived group III+ synthetic (Shell XVHI base stock), not PAO.
I've already forgotten what the "correct" filter for a 4.0 is, because there's plenty of room to use a full-size (Purolator L3001, PL3001 or equivalent) and get more filtration area and an extra half-quart of capacity.
And I'll echo the comments about the silly oil cap being hard to remove. When my daughter and I changed the oil in the Jeep just yesterday (it'll be hers when she gets her license in the fall) and she couldn't get the cap off. I darn near couldn't either, so I coated the O-ring with silicone grease. Helps a lot.
Enjoy your "new" Jeep!
