helo everyone
I'm planning to use auto rx on my accord
f22b1 SOHC Vtec engine
Quote:
Specifications
* Bore × Stroke: 85.0 × 95.0 mm
* Displacement: 2156 cc
* Valve Configuration: SOHC, 16 valves, VTEC
* Compression ratio: 8.8:1
* Max power: 145 hp (108 kW) @ 5500 rpm
* Max torque: 147 ft·lbf (199 N m) @ 4500 rpm
163000KM (101300Miles)
no oil burn
require 4.5qts oil for oil change
Right now i'm using Pennzoil Platinum 5W30 in the engine w/ honda filter
for the best result of using Auto RX
do i need to use whole bottle of Auto RX?
which oil should I use?
- Castrol GTX 5W30?
- Pennzoil Platinum 5W30?
- Mobil 1 5W30? (got 5qts @ home)
- Motul V8100 5W30?
thank you
Quote:
Specifications
no oil burn
- Castrol GTX 5W30?
- Motul V8100 5W30?
thank you
