new compressors generally come pre-lubed we had a special spanner wrench to turn it over and add more oil. it is very difficult to flush parallel flow condensers, and they can retain debris. failure to lube the new compressor will cause instant failure. Other parts such as orifice tubes also need replacing. Note refrigerant is added by WEIGHT as specified, pressures are only used to test the system.
