So I noticed in drive the car seem Like its going into lockup . Does it in 2nd to but if you put it in low and go its fine it only does it on wot or close to it. Fluid is good I noticed when i unplugged tps it idled a hair higher but instead of going then shifting and falling on its face and then realizing so it'll shift down and then imediatly back up does this 3 times or so then it's all good. When the tps is unplugged it doesn't shift back and forth it just goes then shifts to the high gear and stays there. Could it be the tps? There no engine lights and it only does it when taking off at 90% throttle or more.
