So the engine light isn't on in the Camry but when I checked it I got codes 14 41 42. 14 is no ignition signal 41 tps and 42 is speed sensor. Could that be why my transmission is shifting all wacky? Where is the speed sensor? Could a bad tps cause the speed sensor code? I also unplugged the tps to see what difference in running it made so that could be why that code is there. 14 is probably from the ignition tumblers being worn to the point the key can be taken out while running. So that leaves the speed sensor. Can it cause strange shifting mostly noticed under hard acceleration from take off or going unfmder 15 MPH and flooring it? Thanks guys
