so a friend of mine recently started driving a 91 s10 with 2.8 v6. from what he tells me it uses 2 qts of oil a day. he came over to see if i would give him some oil but he wasnt happy when i didnt have anything thick like a 10/40 or above.
anyway first thing i did when he got here was pop the hood and check the oil level. it didnt show on the stick! so i talked him into draining the remaining oil and refilling with maxlife 10/30. i also noticed the transmission was covered in gunk from all the oil leaks. it had to be a inch of gunk!
i pulled the plug and about 1.5 qts came out, it was dark as night. so time to refill and i went inside to get the jug of maxlife when he sees a half gallon of supertech 85w140 sitting on the shelf from a gear oil change last year. he insisted on using it in his engine!! so i figured what the hay, its a completely wore out POS (anyone can see that from a mile away
so his fill was 2- 2.5 qts of gear oil and the rest was a mix of left overs from oil changes, mostly synthetics and mostly 5/30. i guess its better than his other idea of pumping out my used oil from the 55 gal barrel in the garage to use.
he started it up and drove home 40 miles home with out throwing a rod so i guess its ok. but it was very funny to say the least!! luckly i talked him into taking a jug of maxlife home so maybe with time and leaking his sump will have some motor oil in it again
