Zacharyx
I was running the stock bottom end up until the rings went, and decided if it was going to be apart there is no reason to put any weak parts back in. Now it is up t0 302 ci.
I have helped build 3 500+hp 2v cars and have seen the 1019hp one MPH built. I don't see the need to go to the 4v heads to make power, one friend has $15,000 in a 4v with whipple swap into his GT and is putting down 590hp and when mine is together it should put down at least 650hp at the boost level he is running and I barely have $20,000 in mine including the price of the car.
On an oil note, the shop who built the engine said I should break it in on 20w50 Valvoline VR1 but since it is an OHC motor I am scared of oil that thick so I am going to run 10w30 Castrol GTX ( only dino oil I have in the garage)for start up, let the car run up to temp then drain in and run the 30 weight vr1 with the Comp Cam break in additive 500 then again for another 2000 or so. I figure the rings will have no way not to have sealed by then and I will go back to the last of my stash of Havoline Syn and once it is gone may go to PP or AMSOIL.
With as long as the car has been down think I may be on syn in about 10 days
