800/900 watt HFT 2-stroke generator
I HAVE THE HARBOR FREIGHT 900 WATT ONE SMALL AND COMPACK TO TRAVEL WITH , i USE IT FOR TAIL GATES AT THE DRAG RACES SEVERAL TIMES A YEAR AND IT HAS RAN WELL i PROBALBLY HAVE 100 HOURS ON IT AFTER THE LAST ROUND OF STORMS IT RAN FOR A DAY NON STOP JUST TO TOP OFF FUEL , BEEN A GOOD MACHINE FOR 89.00 ON SALE AT HF
WHAT??? I can't hear you. Please shout louder.
Lol. I restrained myself, at least up until now.
I have one of these little buzz boxes and love it. I run Amsoil Sabre oil at a 50 to 1 ratio. I mostly use it boondock camping to charge the trailer battery. It is tough and reliable. Mine will vacuum lock if the fuel cap is closed tightly, so, I leave the fuel cap slightly loose when running it. Best 85 dollars I ever spent.
I have a decent one .Use it a lot instead of cords when using power tools around the place . A lot of times when I run it for longer then 30 or so minutes it will die . I wonder if its vacuum locking . It always starts right up . BUT I always pull the gas cap and look inside so that would let air back in . Gonna try leaving the cap a little loose next time . I had one before this one that died a early death on the charging side due to running out of gas under load to many times . Let them run a while unloaded before running out of fuel or shutting off is my advice . Mine run fine on E0 and supertech 2T .. had to put that in , this is a oil forum .
