Originally Posted By: 1sttruck
Below is some info on Syntorq;
http://www.high-impact.net/nv4500.htm
Additional Info: Here is the response to an inquiry that was sent to Castrol USA about where to get Castrol Syntorq in Europe: "Castrol TAF-X 75W-90 GL-4 gear oil is made in the U.K. and sold only in Europe. However, the equivalent in the U.S. is Syntorq LT. Having said that, Syntorq LT SAE 75W-85, API GL -4 is a premium high performance, synthetic gear lubricant for synchronized manual transmissions. The all new "clean slate" approach enables Syntorq LT to provide consistent performance and durability under the most severe operating conditions due to its unique polymer free formula. It has been designed primarily as a problem solving gear lubricant for manual transmissions to provide reduced gearshift effort at low temperatures. Syntorq LT is available through General Motors (Part #12346190) and Chrysler (Part #4637579) dealerships. Please contact your local dealership."
Syntorq LT sounds suspiciously like like European Syntrans and not TAF-X as TAF_X is a 75W-90 (equivalent here to Syntrax)
Syntrans was specifically developed for ZF, MAN and Mercedes truck transmissions, and also carries a Volvo trucks pt. #.
It's often used in 'problem' synchro transmissions, and is recommended here for race use.
It's a 75W-85 POE/PAO fluid, which appears to have similar chemistry to GC and is rated in truck transmissions to 400,000km with used oil analysis.
11.9 cSt @ 100*C
64.4 @ 40*C
VI 183
PP < -45*C
Syntrans M is heavier again at 18.5 cSt and is specced for Spicer, Rockwell and Road ranger transmissions.
