747F appears to have been loaded improperly- weight inbalance
GON
$150 Site Donor 2025
White Sands, NM
It would be interesting to learn all the steps to get this 747F back on its three points on contact, and back in the air.
No idea- but personal speculation is the freight was not loaded properly, but simply a wild guess.
That's obviously a collapse of the main gear. It definitely isn't a load issue judging by the way the plane is sitting. That main gear is completely collapsed.
Yeah at minimum an inspection with holiday packages being delayed. Possibly repair work needed at a significant cost.
There are two possible explanations.
1. Cargo loading that cause the aircraft to tip backwards. If you load the tail before you load the front, you can tip the airplane over. This happens quite often, but I’m not sure it’s the case, here.
2. Aircraft mechanics making a hydraulic repair and failing to put in the landing gear down locks. When they’re checking hydraulic operation, mechanics will actually raise the gear handle in the cockpit. On the 747 400, it’s a big mechanical handle if you raise the gear handle in the cockpit with the hydraulic systems pressured, you can check for hydraulic leaks on newly installed landing gear actuators. However, you must install the down locks, pins that prevent movement, on each gear.
I suspect they were troubleshooting hydraulics, and did not put the full set of pins in the body gear.
For the record on the 747, the rear most main landing gear trucks are referred to as “body gear”. The two forward trucks, which are normal in this photo, are known as the “wing gear”.
In this photo, the wing gear are normal, but it appears the body gear has been partially retracted.
A little more on the incident. Take it for what it's worth.
"This was NOT a load balance issue, this was a maintenance issue. Maintenance was working on the aircraft's hydraulic systems when the fuselage mounted main landing gear retracted, and the plane tail tipped. This is not a tail strike, this is a tail tip. All cargo doors were closed, and there was no cargo or packages loaded on the aircraft. During the load and unload process UPS requires that either a tailstand is mounted under the rear of the plane, or the nose gear is strapped down with a tether."
