I have a 64 chevelle convertible 3500 lbs, 3.31 12 bolt.
For the moment Im running a 210 hp 305 with a oem 700r4(4L60) from a 1991 pickup with 4.3 l v6. If i remember correctly it was a ck 1500.
I added a ”Corvette servo” from ebay works good. 1-2 is firm softer 2-3 and even softer 3-4 shift. If Im correct its same as a basic v8 700r4?
Built a 355 for it 340-350 hp and 420-450 ft/lbs.(the higher are optimistic its a 10:1 comp 355 with comp XR258, trickflow 175 heads, Edelbrock EPS intake)
What would the 700r4 need to live behind a 355 like that? My hp/torque should be ok with a well prepped 700r4? 99% street(of course it will be fun to do some decent burnouts from time to time)
Parts Im thinkg except a good kit?
Im thinking a smartshell from sonnax?
Boost valve from sonnax .500?
Wider sonnax band.
BORG-WARNER 29236AM
SONNAX 77002BT01 stator bushing
SONNAX 7701001 Sun gear bushing
BORG-WARNER 28571AM
Should I reuse the ”corvette servo” or get sonnax servo?
Shift kit? Transgo 700sk? Or is 700 jr better?
What other parts like steels and frictions do I use?
Reuse the alu pistons? It has alu pistons, right?
Sprags? Can I just upgrade them or are they like 400’s you need a correct drum?
Pump what pump do I most likley have? 13 vane? Ok with 13 vane?
Converter? V6 converter ok with added hp or is a change needed? Hughes? Freakshow? Ok
How about transcooler? Right now an 5 lines to oem style radiator ok? Or is a standalone a good idea even with oem converter? An5 enough?
Im from Sweden so will buy from rockauto they have sonnax and borgwarner parts and/or amazon/ebay for a ”kit”.
Is a kit like this what I want?
https://www.amazon.com/Compatible-T...it&qid=1784169334&sprefix=700r,aps,221&sr=8-1
Wider sonnax band.
BORG-WARNER 29236AM
BORG-WARNER 28571AM
