- Messages
- 8,688
- Location
- SE British Columbia, Canada
As part of the normal process would you replace the rear seal in the engine, since you had the transmission out anyway?
I was wondering about the cost of these two options, (Labor only)
1. Pull 6LX out of truck. Replace torque converter. Put tranny back into truck.
2. Pull 6LX out of truck. Remove torque converter. Open up tranny and re-fresh all clutch material hopefully without a need to replace hard parts. Put in new torque converter. Put tranny back into truck.
The question is for the situation where you have 200,000 miles on the truck and you want to get to 300,000 miles without damaging the transmission. At 300,000 miles either sell the truck or go for the gusto and do a full rebuild.
I find one thing a bit disconcerting is that once that transmission is opened up you are at the total mercy of the tranny shop. I would trust Cline but maybe not some of the other shops out there. Thanks.![]()
Well considering the 6L90E behind the LSA in my car has just ticked over 8700kms, (5400 miles), I'm hoping I'll be good to go for a while yet..However.....I still see 6L90E failures in the 225-250,000 mile range
Thanks for mentioning that. I've noticed three different methods of sealing the plate. Some mechanics, (actually I'm not sure they were pro's) place the plate gasket on with no sealant and put the plate on and bolted up, one dabbed sealant at the two corners at the bottom of the plate, and one carefully placed a bead along where the bottom of the plate would sit. As a separate issue I watched a U tube video where they used a centering device to center the place and to push the seal on afterwards.Yes.....And reseal the Rear Cover on all LSx engines as it's more prone to leak than the Rear Main Seal.
It's a GM trans lol.
I posted this video to show how the centering device works for the Bittog readers. You mentioned sealing. Is there something you can tell us about that topic? Thanks very much. Snag.
Yes I have ordered a seal sub kit for the 1234 35R drum knowing that I will be going back in. The clue is that 3rd bumps occasionally which is the 35R applying on top of the 1234 and of course the 5th bang is the 35R applying on top of the 456. So the 35R is the common factor there. I dont have the software to do a reset. Do you really think it is necessary? I mean the computer is adaptive right?Do a reset & relearn, If that doesn't help.....Pull the pan & see if any left over contamination is present.
The 1234/35R Drum is quite the complicated array of O-rings & Lip Seals.....I've seen experienced builders misbuild this drum!!!
Also, Is the fluid level that critical? I effed up and overfilled the sh!t out of the thing because the torque converter was full already. Today i am going to suck a couple quarts out and pray to the transmission gods but we both know how that will turn out....I have overfilled transmissions in the past and all that happened was they might have vented or leaked some. Never any shifting issues. And yah that drum is a Beeoch.Do a reset & relearn, If that doesn't help.....Pull the pan & see if any left over contamination is present.
And while I have you. What is your take on the compensator feed system? Is one of its functions to act as an accumulator? In other words could the hard shifts be analogous to no accumulation in the older designs? I am wondering if I screwed up that **** piston dam seal.Do a reset & relearn, If that doesn't help.....Pull the pan & see if any left over contamination is present.
Yes, The TCM is adaptive.....But will not make big changes quickly. I always try to leave it be, But if it's acts stupid....I reset them & run a Quick Learn.Yes I have ordered a seal sub kit for the 1234 35R drum knowing that I will be going back in. The clue is that 3rd bumps occasionally which is the 35R applying on top of the 1234 and of course the 5th bang is the 35R applying on top of the 456. So the 35R is the common factor there. I dont have the software to do a reset. Do you really think it is necessary? I mean the computer is adaptive right?
Never overfilled one....But yes, If it's high enough to Foam/Aerate the fluid....That will cause issues.Also, Is the fluid level that critical? I effed up and overfilled the sh!t out of the thing because the torque converter was full already. Today i am going to suck a couple quarts out and pray to the transmission gods but we both know how that will turn out....I have overfilled transmissions in the past and all that happened was they might have vented or leaked some. Never any shifting issues. And yah that drum is a Beeoch.
Compensator pressure greatly affects shift feel & clutch timing, Without it or in the case of a missing/cut compensator seal....The oncoming clutch cannot be controlled & will result in a harsh shift.And while I have you. What is your take on the compensator feed system? Is one of its functions to act as an accumulator? In other words could the hard shifts be analogous to no accumulation in the older designs? I am wondering if I screwed up that **** piston dam seal.
I also have a 2002 Avalon V6 with a terrible oil leak I am working on. Any tips on that? It looks high like valve cover but could be cam seal or cover.
