here is another truck I have in service and I just recieved the UOA results, this engine has had 3 oil changes using mineral oil.
This UOA is using LUBRIGAURD CJ-4 with 5000 miles
Aluminum 25
Chromium 2
nickel 0
Iron 38
Copper 2
Lead 2
Tin 0
Moly 38
Potassium 24 FLAGGED
Silicon 7
Sodium 4
Calcium 1090
Magnesium 742
Phosphorus 1003
boron 1
Zinc 1142
cST Viscosity @100 10.8
TBN 5.15
OXIDATION 9
NITRATION 12
fuel 6.7%
soot 0.2%
The Ford dealer here wont fix nothing this UOA paper they will use to go to the restroom with.
I need this truck but it looks like I will lose this one too!
I am going to drive it till it breaks!
Javier
Quote:
Check for source of FUEL LEAK (injectors, lines etc:). Fuel is at a SIGNIFICANT LEVEL; Lubricant and filter change is suggested if not done at sampling time; Aluminum is at a MODERATE LEVEL; Possible piston metal; FUEL DILUTION has caused viscosity to decrease moderately; Potassium is at a MINOR LEVEL; Potassium sources: coolant (antifreeze), lube additive or supplement, coating on new bearings, rust preventive coating, or environmental; Please provide missing lube type (PRODUCT NAME); Please provide unit model number so we may compare data to the proper standards for this unit;
