It is VW 504/507, which is min 3.5 HTHS.I their product sheet they don't publish ASTM D5481 HTHS which is needed.
TBN is 6.7 which is pretty low for 5w30.
That Valvoline Advanced XL-III 5W30 looks good too and if one had to apply the minimum HTHS it would rank somewhere in the middle on that list based on VII content.It is VW 504/507, which is min 3.5 HTHS.
*I advocate Valvoline Advanced 5W30 (USA) : KV100 = 10.2 and VII is down in the 2.5% range . I trade a lower KV100 (10.2) and a lower HTHS (3.0) in order to obtain lower VII's as my engine is a Hyundai 2.4L (non - turbo) DI . I keep my OCI's low at 4K miles , so hopefully I will achieve good film strength / lubrication and before the oil shears much I will be ready to change the oil keeping intake valve deposits on this DI engine as low as possible . Still , that Valvoline XL-III looks like a very good oil which has better specs VII wise than a number of oils with lower KV100 and HTHS specs. !!That Valvoline Advanced XL-III 5W30 looks good too and if one had to apply the minimum HTHS it would rank somewhere in the middle on that list based on VII content.
This list is by no means saying or is recommendation to pick top rated oil based VII or HTFS and be done with it,
One has to also look at Detergent and Antiwear Additives. TBN and most importantly MFG Approval.
XL-III as far as I know is C3 oil. Not low.I their product sheet they don't publish ASTM D5481 HTHS which is needed.
Just FYI ... HTHS viscosity is what gives "film thickness". The anti-friction/anti-wear additives is what gives the "film strength". The Machinery Lubrication website has a good article about it.I have no clue about HTHS requirements of this particular engine, but if you want "good film strength"
as you say, use oil with HTHS 3,5 or above, which is what this thread is about.
My commuter Equinox's 2.4L DI (non-turbo) engine breaks down oils to the point where they begin to slip by its poor rings somewhere between 2500 and 3000 miles. Oil consumption begins at that point. I suspect our DI engines shear oils at a higher-rate -- more so than in previously owned engine designs.*I advocate Valvoline Advanced 5W30 (USA) : KV100 = 10.2 and VII is down in the 2.5% range . I trade a lower KV100 (10.2) and a lower HTHS (3.0) in order to obtain lower VII's as my engine is a Hyundai 2.4L (non - turbo) DI . I keep my OCI's low at 4K miles , so hopefully I will achieve good film strength / lubrication and before the oil shears much I will be ready to change the oil keeping intake valve deposits on this DI engine as low as possible . Still , that Valvoline XL-III looks like a very good oil which has better specs VII wise than a number of oils with lower KV100 and HTHS specs. !!
Exactly. That is why M1 0W40 is used extensively on track regardless of HTHS of 3.6 and the fact that numerous other oils have higher HTHS. But, that additive package is super strong. But, that SAPS levels are not for any engine.Just FYI ... HTHS viscosity is what gives "film thickness". The anti-friction/anti-wear additives is what gives the "film strength". The Machinery Lubrication website has a good article about it.
The first line of defense againt metal-to-metal contact wear is the HTHS viscosity (the film thickness, ie: MOFT). When that fails and metal-to-metal contact occurs, then the AF/AW additives come in to play to mitigate wear (the film strength).
It's a good oil. Have you ever seen it in 5QT jugs?
I'm hoping to see it packaged like that here soon.I know I'm very late in responding to this but I missed this thread back in February somehow. In Canada we can get Mobil 1 5w30 ESP in 5 quart jugs, and they go on sale at Canadian Tire for close to $30 quite often. Much better than when I originally stocked up on the old formula of this oil, back then it was only sold in 1L bottles and the regular price was $17 per liter. I bought most of it when it went on clearance for roughly half that price. View attachment 59700
That would be nice, but an alternative is Castrol Edge 5w30 LL at walmart.com for a five quart container. Still just a hair over $24.I'm hoping to see it packaged like that here soon.
seems like HPL is no good?There were other 5w30 oils I came across with HTHS =>3.5 but the necessary ASTM test data were missing which were needed for the calculated values.
Was going to also include Liqui Moly oils since there are some fans on here who use it. I saw at least couple 5w30 oils with HTHS listed as >3.5 but not the actual tested value So it was a no-go.
Another time I'll do some other oil viscosities when I get all the necessary data and time.
The results are sorted by VII from lowest to highest.
"Calculated" by what appears to be a former member.seems like HPL is no good?
I agree. The real results are where the metal meets the meat so to speak.I’m quite comfortable with our real world results vs a spreadsheet in theory.
David
Restore for Cummins.Valvoline makes an oil to clean engines up, ester based. I'm sure others will chime in, it's sold at dealers as it's made for 1 engine brand. Can't remember which though.
