Originally Posted By: tig1
Originally Posted By: KCJeep
There is very little a 5w20 will do that a 5w30 won't do as well or better. About the only possible advantage to the 5w20 is cold starts and it is small, you can easily find 5w30's with better cold crank abilities than say a 5w20 dino. I will take the 5w30 thank you.
So what's the advantage of a 30wt over a 20wt then? I may very well have been using 0-20 longer than most here,(used M1 5-20 in the late 70s in an engine calling fo 10-30) and have found it to be outstanding in all temps. I like the way my engines start in cold temps and perform in hot temps. My engines use no oil between OCIs and both are very clean through the oil fill hole, so the 20wt isn't showing any signs of oxidizing, or do my engines show signs of wear. This is all at 10K OCI's. Now if my engines called for a 30wt then I would use 5-30 in this day and age. You simply can't prove your point that a 30wt is better for your engine if it calls for a 20. Now opinions are just that, opinions.
Assuming HT/HS follows I can prove 30 grade is better at higher sump temps. However for typical street use it's likely a non-issue.
