In a modern double overhead cam engine where external temps rarely get below 20 degrees F. is there going to be much of a difference / time lag between 5W and 10W synthetic oil in getting the oil to vital engine parts for rapid protection ? For comparison , let's say the external temp is 20 degrees F. and the only difference in synthetic oils used is one is a 5W and the other a 10W. I will also add we are talking 20 degree F. temps a maximum of only a possibility of three months out of the year so as external temps rise then less of an issue between 5W and 10W at start up - or technically 5W always has the real world edge in start up protection over a 10W oil ... Your thoughts ?
