5W-30 Shear question
Houston, TX
Is it true that most 5w30 conventional oils shear to 20wt after little use? The dinos that I usually use are MC5k and Havy DS 5w30. If this is true in those brands, I want to go ahead and use MC 5w-20, especially for the price with performance. Oh my engine calls for 5w30 too.
I would say no, that statement is not true.
Some 5w30 conventionals shear to a high 20wt depending on the application it's used in and how it's used.
I've had 5W30 shear slightly, but never any into the 20wt region. Some have though.
Most of the used oil analysis on 30 weight oil show them staying in grade. Occasionally, given the right engine and service life, one will shear down to a 20 weight.
(all stuff so far)
However ..5w30's ..of perhaps the same vintage as your car MAY have been more shear prone than those of today.
My understanding is that oils will shear down and thin a bit.
But not after 'a little' use. More like 3k+, and not a big deal.
Dino is worse in this respect.
If an oil is really old and beat up, with abuse and heat, it can start to thicken. But this is way after an oil change is due, and is unusual.
Most of the bad shearing took place with older formulations with weaker base stocks and VI improvers. The new modern day oils are less likely to have the same shear rate. When the new GF-5 oils come out they will be even more shear stable. Use your 5w30.
I've looked at 5w30 conventional shearing a few times. Seems most shear to 20W. Looking at five used oil analysis posted here today on the first page, the 5w30 conventionals sheared as follows:
Brand OCI 100C Vis.
QS 2800 8.2
Chev 4900 9.0
Val? 5300 9.2
GTX 2500 8.3
Shell 5200 8.8
SAE J300 specs 30W 100C Vis. as 9.3 min. So all 5 above sheared to 20W. Basically the same results I saw last time I looked.
Conversely, last time I looked, most syns stayed above 9.3 (30W)over the OCI.
I agree - most 5w30 shear, but not that badly. Most end up around 8.8 - 9.2 cst, and that is right at the upper end of a 20-weight. It's not like a lot are going down into the 7-cst range.
conventional is worse in this respect.
It appears to my untrained eye, in reading many used oil analysis, that many of the engines that tend to shear traditional 5w30 conventionals also tend to shear traditional conventional 10w30 oils as well. Would you agree with this?
If you see energy conserving on the label, you can count on it shearing to a 20wt. If it doesn't, consider yourself lucky.
Brand OCI 100C Vis.
QS 2800 8.2
Chev 4900 9.0
Val? 5300 9.2
GTX 2500 8.3
Shell 5200 8.8
How many were fuel diluted?
How many were turbo's?
Flashpoints?
Some engines appear to shear oils. The same oils don't "routinely" shear.
Brand OCI 100C Vis.
QS 2800 8.2
Chev 4900 9.0
Val? 5300 9.2
GTX 2500 8.3
Shell 5200 8.8
Flashpoints?
Gary,
Do you have data for any dino GF-4 5W30 that doesn't shear over a typical OCI in a most non-turbo engines it's used in?
