I cleaned my chain after riding while it was warm with WD-40 sprayed on blue shop towels,
I employ good old handy Gas to a rag and degrease chain and wheels...
I employ plastic polish to add a nice luster to the wheels...
Looks great!I employ good old handy Gas to a rag and degrease chain and wheels...
Your chain looks just a bit lose...
Kerosene easily cuts every chain lube I've ever used, including wax based chain lubes. Kerosene is safe for all materials too, and called out in manuals as the preferred cleaning solvent for O-ring chains.Looks great!
I find that chain grease or gear lube clean up very easily. It is the various waxes with their no sling formulas that can be hard to clean up and often require stiff brushes and harsh chemicals, which incidentally are not so kind on the very o-rings we are trying to protect.
However, WD40 seems to deal with the waxes pretty well in my experience.
Mercy 02SE... It frees up the ponies like a 30 wt, doncha' know?![]()
So are you actually running a clip and rivet master link on the same chain?
As a former aircraft inspector I am going to state the obvious - somebody needs to work on their safety wiring skills. Sorry.
I bought a can of this a few months ago for $6, to use on my bicycle. I'm truly impressed with this stuff.Been using WD-40 Specialist Roller Chain Lube on motorcycle and bicycle chains for years.
X/O Ring chains have grease sealed inside the critical pin/bushing interface. Critical for sealed chains is to lubricate the SEALS so they stay slippery don't dry/crack or leak grease out or allow contamination in.
Negative... the 4 points of an X ring are as effective as your fork seals in
separating external and internal fluids and don't require lube...
You can submerge the chain into a sea of oil and not one molecule will migrate
pass the effective X ring seals held in tension to lube the seals...
Currently we have the X rings designed out of the new fluoroelastomer
product known commercially as Viton or Kalrez and reasons are:
1)Excellent Resistance to Drying Out
2)Low Drag
3)Seals at 4 points
4)Grooved Reservoirs of Lube
What that means for us is the fact Viton or Kalrez X rings will be
100% serviceable far beyond a chain's first adjustment mileage point
where metal to metal wear begins to happen at the critical pin and
roller junction...
If you wish to lube reach the critical pin and roller junction just
remove X rings with razor knife...
I don't think you read what was said. The X/O seals made out of whatever miracle material are still subject to wear. So dust and grit can tear them up just like fork seals engine seals etc. And once the seals get worn they will leak (Only takes one) and you have hundreds of them on one chain. Once damaged grease will leak out or grit will get in to contaminate the grease. If you want to have nothing on the seals then do so. I keep mine wet with something i know will help them slide and not degrade.Negative... the 4 points of an X ring are as effective as your fork seals in
2)Low Drag
3)Seals at 4 points
roller junction...
