Guy evaluates 55 motorcycle chain lubes. It’s a UK Based show, so many tested are not readily available in US. Not sure the methods used are totally valid. But, gear oil and Maxima Chain Wax show to be good options.
Couple of my bikes have Reservoirs for motor oil with a pump to lube the chain. I’ve used gear oil and motor oil but prefer Maxima.Wax. Clean, does not attract dirt much and seems to lube fine.Many years ago Dirt bike magazine tested chain oils and regular motor oil scored the best. I used to take my chain off(once in a while) and put it in a container with used oil and then hang it up to drip off back into the container(old jerry can) Otherwise I used whatever chain lube was on sale or an old pump style oil can and wiping off with a rag. A bit messy but ok with dirt bikes, I prefer shaft drive for the street.
I've tried every chain lube I could find over the years. The top one is still my favorite.With the above liquid wrench lube, the "penetrant" part of the label would be of potential concern for me personally with an X-ring or o-ring chain.
Below... Both these lubes are fantastic. Under $10 a can. Moly version has no fling/mess, period. "White Graphite" version is so low on fling/mess it may as well be no fling. Over 33,000 miles on an EK ZVX2 530 chain. Moly version gets the most use, white graphite goes a bit longer but has as hazy look to it that the moly does not. Pick your poison, either is great. Because of the low mess with either, "cleaning" the chain is easy with a wipe down.
I've had good success with Motul Chain Paste as well, more difficult to keep from getting "too much" on the chain and then it will fling, but lasts a good while between lubes. View attachment 71144
Regular gear oil, thinly brushed on is my favorite method. It leaves a lot less mess than many claim and is easily wiped just with a rag. No solvents or cleaners needed.
Fresh application. I would oftentimes ride right afterwards with very minimal sling.
Here is the sprocket area after one season of riding.
And here it is after a quick wipe with a rag.
The center rollers are not sealed. Lube needs to wick in from the sides of the rollers and get underneath them.Most chain driven street bikes have an X/O-ring chain. Don't want/need the external lube getting inside the pins and rollers. The X/O-rings keep the factory grease/lube from leaking OUT.
I'm thinking of when I install a new chain, I put white grease on the pins that go into the roller and the o/x-rings seal that in. Of course, all the pins/rollers have grease/lube sealed inside as well from the factory. That's what I am referring to when I say we don't want lube coming from outside to displace that.The center rollers are not sealed. Lube needs to wick in from the sides of the rollers and get underneath them.
Chain "rollers" are the sections of the chain that makes contact with the sprocket teeth - they have the ability to "roll" in place. They are not sealed by any means. Chain lube needs to wick down through the gaps at the ends of the rollers to get inside them. The rollers are really the main area to lubricate on a sealed O or X ring chain.I'm thinking of when I install a new chain, I put white grease on the pins that go into the roller and the o/x-rings seal that in. Of course, all the pins/rollers have grease/lube sealed inside as well from the factory. That's what I am referring to when I say we don't want lube coming from outside to displace that.
