I'm in need of a wrench which can do 25-30NM. The thing is that they're extremely difficult to find and those I do find are either priced well over $50-$100 or don't don't NM. Ne1 have any suggestions?
You don't need the wrench to actually have NM on it, you can always do the math and convert to ft-lbs - add 35% to your NM figure.
Probably best off to buy an inexpensive 3/8" wrench to cover this. Cheap ones are fine unless you are doing critical stuff with them, like rod bolts or something. Even then you should probably use a stretch gauge.
I don't need super precision I'm just looking to torque within the 25nm-30nm range and as I understand it you want your target to generally be within the middle to upper middle range of the torque wrench hence the 50NM. I'm just finding that a lot of cheaper wrenches have the upper/lower limit around 20-25 NM.Do you need it super precise on NM for some reason, I don’t remember ever seein a ft lb tw without a nm scale on reverse side…
Great idea. thxLook for bicycle tools, I have on that does NM and was under $50.
Great idea. thx
Ya it tops out at 16nm.I bought the Tekton 1/4 inch drive. It has Nm range as well.
Unless you're working on something super precise you're fine using either far end of the scale. Even my cheap torque wrenches are within 0.5% on the bottom setting.I don't need super precision I'm just looking to torque within the 25nm-30nm range and as I understand it you want your target to generally be within the middle to upper middle range of the torque wrench hence the 50NM. I'm just finding that a lot of cheaper wrenches have the upper/lower limit around 20-25 NM.
Great idea. thx
I have mine lent out to one of my brothers right now, but if I remember right the 1/4 does not go high enough in range for the OP. A 3/8 would, but that would be on the low end of the wrench and less resolution on setting it, but still quite usable.I bought the Tekton 1/4 inch drive. It has Nm range as well.
