Hi Guys - My 2009 Tahoe with the 5.3 and cylinder deactivation has recently started to burn about a quart every 1500 miles. The last OC was 2 quarts Valvoline MaxLife High Mileage 5w30 and 4 quarts 5w40 M1 because I thought I had more Maxlife laying around and it was all I had. Filter is a Fram TG. I'm at 7k on the OCI right now and just put in my second quart of Maxlife makeup.
I normally would not have used more than a quart makeup at this point. It is perfectly dry underneath and on the garage floor. No smoke seen or smelt. Do you think the 5w40 had something to do with it? I usually would run it to 8-10k so will be doing a change soon. Should I try another oil? Go with an HDEO? It does get into the single digests in the mountains here in Northeast PA pretty often this time of year. I do drive about 30k a year so can change oil often. The truck has had a steady diet of Maxlife for the past 100k.
There is 211k on it now and it runs smoother than ever and I want it to get too 300k. Thoughts are appreciated. Cost of oil is not too important to me as it is pennies compared to the overall cost of the car.
