Just bought this '97 Catera with 57,000 miles and it was a challenge to get it the 30 miles home. Seemed to delay 1-2 upshift and couldn't get 3rd for a while. Also seemed to be slipping sometimes. Went into limp mode after a while into 3rd so I dreaded every stop light but at least could go 50-55 now. Anyway, when I got home and scanned it, only has code P1870 for TCC stuck off. I'll check the fluid first, but no dipstick on these. Then I guess I check the TCC solenoid? Is there a resistance spec? And if it's supposed to be either on or off, can I put 12V and ground to the pins and see if it works?
