Hi,
This is for a Corolla 2010 1.8.
I have ABS, TC and VSC(off) lights on the dash for a while now, and I've recently decided to start testing things.
Scan tool gives me C1361 code. No other codes.
Short circuit in motor fail safe relay
Two recommended fixes are:
REPLACE ABS PUMP AND MOTOR RELAY
REPLACE ABS PUMP AND MOTOR WIRING HARNESS
A few things I've already checked
- Battery and charging system
- checked the STOP fuse already as this is used by the ABS module to initiate, and it's fine along with the brake lights.
- checked the 2 positive and 2 ground terminals at the ABS module harness, all tested fine.
- cleaned all ground connections and terminals on alternator, battery terminals etc..
The battery is a little iffy to me. I did a simple load test with the high beams, and it does seem to hold charge. Drops a little bit overtime but not too much immediately.
However, there are times where the battery does seem to not hold charge when the car is off, and goes below 12 volts.
Overall, starting the car not an issue. I may just replace the battery anyways, but I still don't think it would be causing the C1361 code.
I was doing some frontend work and I replaced the front ABS sensors at the same time and still had the issue.
However, I did not test/replace the rear ABS sensors/lines yet, which I think should be my next step.
The ABS fuses/relays seem to be fused into some white box so not sure how to test those, however given that the ABS module does get power through the wiring harness, I don't think that's the problem.
There are recommendations that the ABS module internally itself is a problem, which I refuse to believe at this point. The car is also low mileage and it doesn't seem to be a common issue.
Would appreciate any recommendations or ideas.
