4 trouble codes on the max
I have $100 in credit card rewards help up in Amazon though and I want to use that up if I can instead of using money.
Does your state have any laws about passing a state inspection within a week of sale? Do you need the CEL off to pass inspection? Run, don't walk, to a nissan dealer for a full thorough inspection if this is the case, and document everything.
You can clear the codes by pulling "the right" fuse, whichever that is, there will likely be several ECM fuses.
Originally Posted By: asiancivicmaniac
Nope. The good thing about Florida is that there aren't vehicle inspections.
Oklahoma is the same way. I miss living there. Stupid inspections.
Wouldn't florida then become an auction dumping ground for all the out-of-state lemons?
None of those codes are that serious, but of course if your CEL is on and something serious pops up, you'll never know.
Will I screw something up if I pull the wrong ecm fuse?
nope! have at it!
The fuse box for the ecm is in a really tight spot and I couldn't fit my hand in there. I tried the gas pedal trick and got the thing to flash but the instructions said there would be a sequence of 3 sets with 10 flashes each set. It flashed five sets and kept on doing it so I just continued. The light is still on. I'll try again Friday and let it flash until either it stops or it keeps flashing after several minutes.
Kind of neat the gas pedal can get it to flash.
