4,541 mi Mahle OC 614 Cut Open
Tampa Bay
As a follow up to my virgin filter cut open here
This is a Mahle OC 614 changed at a little over 4,500miles. Oil of choice at this change was Phillips 66 Shield Choice 5w20. As per my conversation with mahle they rate these filters up to 10k which I have no doubts this thing can go that far. This isnt even half of their reccomendation and it looks amazing, and at a 95% @ 20 microns efficiency rating, this 3$,filter is what the Purolator made 9$ MOPAR filter should try and be. If you are looking for OEM replacement that isn't gonna break the bank for your Hemi or Tigershark engines, i suggest this.
The only thing that would make this filter better IMO is a Silicone ADBV.
This cross references with
Fram 10060
Wix 57060
Purolator L12222
AC Delco PF48
Mopar MO 339
Enjoy. Filter was purchased from rockauto.
Outside
Date code: Probably Week 27 of 2018 is my guess. Looks pretty decently built, thanks for the C&P.
Originally Posted by oilboy123
I have bought a few of the Mahle. Looks decent. But what I want to know is how you cut the filter so neatly open?
Tin snips..
Originally Posted by BlueOvalFitter
Thanks for the C&P.
Weld it up and give it to one of the many members here that use the same oil filter for multiple OCI's.
Nah id just sell it as a cartridge filter. ...„
Originally Posted by Farnsworth
How do you do it so nice with tin snips? How is it started?
I remove the gasket prior. Usually a crude cut at first then a cleaner easier cut after. I place a flat head screwdriver in the center tube when done to pop the element out afterwards.
ingenious!
