Originally Posted By: CapriRacer
Sorry, but, No, that does not work.
Ya' see, the wheels have a tapered seat that exactly fits the lugnut's taper. (Yes, there are exceptions, but this is not one of them!) If the lugnut isn't properly seated, it will wear the seat oblong.
Not to mention the difficulty in getting the wheel centered on the hub.
I'm with CR on this. Glad to hear you didn't do it. I've seen it far too many times. The lugnuts won't seat correctly, the holes will wear badly, the wheel will not center, the studs will bend and the car will shake at speed.
Of course you could go ahead and pre-damage the bolt holes by making them oblong. This has the advantage of being impossible to get right and weakening the structure that holds the wheels on the car while still causing all the same problems. That would be awesome.
I'm kidding. Don't do that.
