Originally Posted By: MrRPM
my jeep is a 2001, can you give more information about these piston skirt failures? is it due to lack of lubrication or [censored] pistons?
Piston skirt failure is NOT common on a 4.0. It does happen, but its still very rare and I personally think it comes from over-revving while mudding, generally.
The bigger thing you HAVE to watch for on a 2000 or 2001 is the "331" head casting, which is prone to cracking between cylinder 3 and 4 under the valve cover. It won't lose compression because the crack doesn't go into the combustion chamber, it just gets water in the oil and then ruins the main bearings. If you have a 2000 or 2001, then DO NOT ever let it overheat! Keep an extra watchful eye on cooling system components and if it ever starts to run hot, SHUT DOWN faster than you would most iron-head engines. Watch the coolant reservoir really close (I check mine at least once a week) and if you notice coolant disappearing, have the oil analyzed to see if there's coolant in it.
