3mz-fe catastrophic new cam seal failure
The ones I have used all came with the installation tool already in the seal. Clean the shaft with brake cleaner and a clean lint free microfiber cloth, put tool on the shaft and push the seal over the tool, seat the seal and pull the tool out.
Do not remove the guide tool from the seal prior to installing it for a look see, never lube the seal and do not touch the PTFE part of the seal. Wash hands before messing with these seals, cleanliness and handling with care is everything. I recently did the timing chains on my own car and replaced this RMS because I was in there already (timing chains in the rear of the engine), replacing it again if it leaked would require removing the engine/trans again. The white ring is the install tool part.
Is this much ado about.....something? ie is the PTFE superior in life span or other attributes in practice?
They are superior to normal seals that use a tension spring, the PTFE acts as a lubricant, has low tension so it causes no wear to the shaft (this is one of the biggest benefits) that can cause leaks as they age, the PTFE seals do not age and are resistant to almost all chemicals as well as temp extremes (IIRC -almost -350f to +500f).
The issues with PTFE seals are installation error or using the wrong seal which is very common. You may see regular seals along with the PTFE being offered for the same engine.
On euro cars this is where the fun can begin, not only are there transition years but model year in Europe begins 1/1/xxxx in the USA anything after 9/1/xxxx is considered the next year. You can replace PTFE with regular seal without issue but not a regular with PTFE, if unsure go with the regular one, if it has a PTFE then go with the same.
  • Like
Reactions: D60
WOW !! Did I get lucky ! ( Feel terrible for you Kurtatron....all that work to do it over :( )....Anyway, did a timing case crankshaft gasket on an 03' - Toyota 2AZ-FE engine. Ripped the old one out with a screwdriver, ( really marred up the mating surfaces too ), then dunked the whole seal in dielectric silicone, smeared it in and around the gasket good, then took a small hammer and slowly tapped it in. Put the harmonic balancer back on, then the belt, and started it right up. No more leak. I feel so bad for you. Looks like you did everything PERFECTLY,,,,,,,and her I am working like a neanderthal on basically the same thing, :(
You’re quite a mechanic.
Hey, when you're workin in the street, and cars are whizzin past you, you learn to get the job done ASAP before you get killed. A little back story here for all my HYSTERICAL BITOG buddies here. On the weekends, I had a job taking care of 25 delivery cars for 3 pharmacies. Trying to save $$$ to buy a house. Did the local utility company during the week, and the cars on the weekend. I was still living at home, 17yrs old. One rainy weekend day, my old man comes out of the house, and demanded $50 per car to use his " driveway" to do my side job work, ( off the books mind you...good money ). So, I looked at him and said " I'm trying my best to get out of you're house and you're precious garage that you don't use, now you want $50 bucks a car for driveway usage ?!?! The rent I give you once a month doesn't cover that ?!?!" ( Mind you I'm soaking wet and full of grease )....Let's make a deal, I say. I'll go work out in the street in order to stay off you're driveway, and you remove the $50 dollar shake down. Is it a deal ? He says " Well, being that you're soaking wet, and work 7 days a week, I think I can forget the $50 bucks " I say, thank you so much !!!!! I'll be out of you're hair even faster now. You're THE BEST !!! So, out in the street I go, workin on cars, with other cars flyin past me at 40 mph. Oh, the house was 20' from an intersection also. GO SCRATCH KSCHACHN & D60 !!!!!!!!!!!!!!!!!!!!!!!!
Here’s pics of the old seal pulled out. I ran my finger along the cam nose and felt no ridge. I’m at a loss how this happened. The other cam seal has no leaks.
Can I test for a clogged PCV by feeling for pressure under the dipstick?
This time around the timing belt redo is going much easier. All the bolts are fresh and easy to undo.
I replaced camshaft seals in our late great '97 Mazda MPV as part of a TB job back in 2014.
I left the TB covers off, as I like to start the engine and run it for just a few seconds to make sure all's well before buttoning everything up. There was a harsh screeching noise upon start-up. The seals were ruined. Arg!
I picked up new ones from the dealer, and asked a tech if I should have lubed the old ones before replacement. Yes! Oil or grease? Doesn't matter, as long as you lube them!!!
Lesson learned!
You rolled/cut it during installation.....Pressure would push a seal out before doing that.
I’ve always applied a liberal amount of grease to the ID of a seal. Never had an issue.
Toyota doesn’t use PTFE seals - they’re either neoprene/nitrile or FKM(Viton). PTFE seems to an aftermarket thing, more for rear main seals. Fel-Pro has many of those.
It sucks when you do everything right, and it still goes wrong
I have a master's degree in failed best efforts 😭
Did you use an OE Toyota part?
Because I've got some on the shelf for my 3MZ timing belt job, they have a greenish lube on the ID of the seal
The service manual works on the assumption that you have the rocker cover off, and the cam cap off
I think the seal installer we all use was invented later
It does say to lube with MP grease, and not to expose it to engine oil for 2 hours
Not clear if it means the packing (Toyota FIPG/RTV) or the (cam oil seal) itself
Good luck with the do over
We've all been there 🤷‍♂️
