3mz-fe catastrophic new cam seal failure
The ones I have used all came with the installation tool already in the seal. Clean the shaft with brake cleaner and a clean lint free microfiber cloth, put tool on the shaft and push the seal over the tool, seat the seal and pull the tool out.
Do not remove the guide tool from the seal prior to installing it for a look see, never lube the seal and do not touch the PTFE part of the seal. Wash hands before messing with these seals, cleanliness and handling with care is everything. I recently did the timing chains on my own car and replaced this RMS because I was in there already (timing chains in the rear of the engine), replacing it again if it leaked would require removing the engine/trans again. The white ring is the install tool part.
Is this much ado about.....something? ie is the PTFE superior in life span or other attributes in practice?
