3mz-fe catastrophic new cam seal failure
Atlanta
I changed the timing belt 2 months ago on this Lexus. The work included the two cam seals.
I had done this job on a 1MZ before and had no problems with that job.
What could have gone wrong? I used a pvc pipe to perfectly install the seal just like the Toyota tool.
I don’t remember if I applied any lubricant to the seals prior to install. I think I skipped that because I read somewhere to install them dry.
It sucks because I have to do this job again. 😞
Looks like the lip was torn on installation and failed there. No lubrication on the outside, but absolutely a thin film of oil on the lip to help it slide over the cam without tearing.
On typical rubber lipped seals, yes always lube. However some newer PTFE seals specifically state not to lube - at least to my eye they're pretty easy to spot, so even if they're not labeled you can tell what they are and install dry.
Wow that is VERY interesting about the settling time for the PTFE seals. I could see if it was very cold when the job was done and having a problem but in normal temps I would think with a few minutes you could start the car. That's pretty nuts.
Problem with people is they seem to rarely THOROUGHLY read instructions for things like this job...sorry for the redo.
That's curious about the settling time as I've never seen any instructions included with PTFE seals that state it needs to be done.
Techs should demand four hours added to flat rate. Procedures like this are stupid ‐‐ who has the time? Furthermore, unless you finish a customer's car by ~noon, they can't pick it up before COB
I'm not sure this would apply to all PTFE seals, I found that when searching for PTFE seals installation instructions.
I've never heard of installing a seal dry. And this caught my attention - as I never would have guessed that.
Corporate management often doesn't consider the real world in their decisions.
There have been many procedures that require a vehicle to sit for a period of time.
Example: a software update that takes an hour to complete, and the procedure only pays enough time to hook up the equipment, and verify proper completion of the update afterwards.
When an inquiry is made as to how this is to be accomplished, the answer always involves using a "spare work bay" that doesn't exist.
When the lack there of is pointed out, it's not their concern that your employer doesn't provide such extra spaces.
That's my though too. Tore on install.
When I put a rear main in my truck I used a McDonald's cup to slide the new seal over the crank shaft without damaging it. Wonder if something similar could be done here?
How do I know a seal is ptfe?
From what I've read - no experience here - the PTFE seals have no spring.
Open the link from @Trav and there's an illustration of the lips in that.
It does appear to be very important to use a tool, to get the lips safely over the shaft.
