occupant
Had to do the oil change a wee bit early. About 280 miles in towards the 500 I wanted to do and the 1000 the mechanic recommended I started getting serious cold start valve clatter, ticks, clicks, clacks, and bad metal sounds. So I drove to the corner QS lube place and they got it done. $28 out the door and I have fresh oil, fresh filter. Funny part is, when the guy went to drain the oil...
NOTHING CAME OUT!
That is not to say there wasn't oil in there. It was in there riding on top of a thick cushion of Dexcool Mud. He had to poke a hole in it with a socket extension just to get a flow started and then all this mess came out. He said there's no way I would have made another 20 miles let alone 200.
So yeah. Kinda freaked out about that.
Van runs even better than before now. I think in another 300 to 500 to 1000 to 1500 miles I will do an engine flush in addition to an oil/filter change. This way if there is any more mayonnaise or pudding or fluffy junk in there, it can drain out with the hot oil and maybe not stay stuck in there any more.
Also I got my headlights and marker lenses on, changed the wiper blades, smacked the overhead console with my thumb and forefinger a few times and the display popped back up. Should be able to fix that with a little soldering work, I'm sure there's just a poor connection in there. And the power sliding door, I found out why it wasn't working right, the little tongue-shaped plastic piece was broken off and stuck askew in the little hole it's supposed to go in. So I took that out, door works fine, need to get a replacement tongue thingy.
Now that all the air is out of the cooling system, it warms up quicker, gives heat quicker, stays cooler, doesn't go over halfway, and no bubbles or gushing when you shut it off after a long idle. Glad I replaced those bleeder screws so I could do it right again. Very relieved the head gaskets are holding their ground.
NOTHING CAME OUT!
