I posted here a while back about my 305 and an air pocket issue, which I thought I had solved. The truck runs cold when it's cold out, and overheats when it's warmer (in the 40s or up). I've tried 2 thermostats and am about to just remove the thermostat and run it without one to see if it still overheats.
I did some research and read that these trucks with serpentine belts use reverse rotation water pumps. Back when I got it I installed an AC Delco P/N 252-719 water pump. I just learned about reverse rotation pumps and am wondering if this pump is standard rotation. I had to install my old pulley on it so no idea if it's meant to run the other way.
When I ran the part number on AC Delco's website, it listed that pump and P/N 251-725. Neither lists rotation. I called AC Delco and customer service suggested I call a garage (thanks).
Does anyone know if these pumps are different rotation styles?
Thanks.
Thanks.
